Hi All,
I'm not sure if this is a problem or not but the Y axis Prox switch light doesn't go out even when the switch is made up. Both X and Y lights remain on as they are supposed to when running normally but the X light goes out when it gets made up; the Y doesn't.
They appear to be functioning properly in that they both stop carriage movement when they are made up.
I had to change the default input value in the control software from the default normally closed to normally open before they would work. I double checked the wiring and it is correct according to the manual.
I have a PRSalpha with a 4HP HSD spindle. I have just got it set up and am trying to learn how to drive it.
Thanks in advance.
