I've made a 2d cutting toolpath for a sheet of plywood that will ultimately be assembled into a piece of cabinetry. Instead of going back into Fusion 360 to generate a mirrored version of the toolpath, can I simply go into the VU settings and put a negative in front of the x unit value or the y unit value?
It seems like this would be an expedient way to generate a mirrored version of a toolpath but perhaps this can generate a climbing to a conventional cut (or vice versa) in certain situations. Any help with best practices is appreciated.
Regards,
Mike
