Results 1 to 9 of 9
Thread: Vests motor
    Oct 2005
    Timberline, St .George
    Default Vests motor
    I need to reverse one of my x motors on a prt96 Shopbot
    Vexta a6497_9412 ktg. Need to change the
    Physical wiring to reverse on the motor connector
    The wires on the connector is black green blue red
    Thanks for any help
    Dec 2008
    , Richmond Tx
    They are paired in the plug. Two on one side and two on the other. Reverse either pair. They come out very easy with a tab you push in on the connector going into the controller.
    Kenneth
    Oct 2005
    Default vexta
    Quote Originally Posted by ken_rychlik View Post
    Hi Kenneth thanks for your help just to make sure i have this correct
    from the left of the plug the colours goes red blue then green black
    so one pair will be red blue and next pair green black
    this will become green black red blue? trying not to make smoke
    Oct 2005
    Quote Originally Posted by paul60 View Post
    Or should I just take the red and blue and exchange there position so it become from left blue red
    Dec 2008
    , Richmond Tx
    yes switching the red and blue in the plug should make it run the opposite way. If you are comfortable with a meter, each pair has continuity and no continuity between each other.
    Kenneth
    I always just switch the green and black
    Oct 2005
    Hi Kenneth
    Got it working
    Now another problem has come up one of the stepper start making making allot of noise. I took of that motor and connected it to the smooth working motor supply and it work smooth.
    can a Geckodrive cause this problem? G203v using a meter is there a way to test a geckodrive where can i find this info i have replace the break out board PMDX-122
    any help will be welcome
    thanksPaul
    Dec 2008
    , Richmond Tx
    So if you are not on the shopbot software, I would put leadshine drives in it. Smooth, quiet, and less motor heating. DM556E or DM860E Depending on your supply voltage. Look up automation direct
    Kenneth
    Hi Kenneth
    Got it working
    thanksPaul
    Did you hook the other motor up to the noisy drive. It may be a loose wire going to the Gecko. Are you getting all green lights on the Geckos and is the resistor hooked up
