Thread: Zeroing ATC tool without plate
    Jul 2022
    Default Zeroing ATC tool without plate
    I have a PRS Alpha with ATC and a 5" orbital sanding head. I want to zero the sanding head to match the tools in the rack, but because of the size I can't use the normal CN72 method. How would I go about doing this?
    Oct 2000
    Willis Wharf, VA
    The quickest way to get an answer is almost always to contact the folks at ShopBot support. They will get you sorted out.
    In a nutshell, without hashing through all the macros used for SB ATC, my thoughts would be to assign a X/Y offset if Tool# (# being the sanding head) is called, which would then position the sanding head at a location that would allow it to be set. For example, instead of the head center, use an offset to the outer edge of the disk.
