I have thought (procrastinated) about how I was going to make my vacuum table and layout for the past two years. I do all types of cutting with the shopbot and wanted the flexibility to control cutting everything from full 5 x 12 sheet material down to smaller pieces, plus the ability to hold long boards. My final decision was to use 13 zones. I tried to lay them out to fit most any situation. The enclosed picture depicts how they are laid out. Of course there will still be times I will need to mask off a small area. The total cost for all plumbing was just under $300.00.
I started my layout with four sections 5 1/2 inches wide. This area was created to hold down long boards. The breaking up into four sections was to help align with the second row. The second row starts with 2 foot wide sections, expanding to the width of a 48 inch sheet. Combined with some sections from the first row. I can hold down portions of four by eight sheets in 2' x 4' increments. The remainder is broken into sections so that I can hold 5' x 8', 5' x 10', or 5' x 12' sheets.
So far, yesterday, I cut the Plenum into a 5 x 12 x 1 inch sheet of MDF. Today I will be putting on some epoxy paint as my sealant. I chose epoxy paint for two reasons. The first reason is I happen to have 2 gallons of it sitting on my shelf for the past six years. The second reason is, after testing it on a piece of MDF, I found that it seals far better than anything I've used in the past.
After reading other people's solutions on this forum I decided to start with a Fein vacuum. I purchased a Fein Turbo Vac IV on eBay for $350.00. Depending on my results I may purchase a second Fein, or if need be I will move up to a blower. I can certainly afford the blower, but I chose the Fein for its better noise control. I might add that you do not realize what people are talking about when they describe the power of the Fein. When I plugged it in yesterday for the first time and felt the power of it I was blown away. I have four other shop vacs here, some costing twice what the Fein cost, but the Fein is far more powerful than any of them.
I will update as I progress.
See larger picture here http://www.theaterrooms.com/vacuum.htm
