I have just installed the Milwaukee router on my bot and discovered I am not sure how bits go into it . I loosened the collect nut and tried putting a 1/2" bit into it and it was way to tight to take the bit so I removed the collet nut and still no luck . I tried pulling the collet out with my fingers but it appears lodged in there . The PC was quite simple in this regard as it would release the bit and you could easily insert a new bit but it appears there is a trick to the Milwaukee that escapes me and is not described in the manual . Should the collet have come out when I released that collet nut ?
Thanks Bill
