Folks -
How often do you resurface your spoilboard, and for what reason?
We've had the 'bot about a year, and originally had two layers of 3/4" mdf... Doc Palumbo said that it would move around, and it did! So, off came the MDF and we then went with 3 layers of 1/2" ply, glued the entire sheets, including edges and screwed on 6" centers throughout on each layer, then added two layers of tempered 1/4" hardboard (masonite) glued without screws. While all of this was drying, we stacked the table with several sheets of plywood, dead elephants, dark matter, oceans, etc. to keep it evenly flat and weighted. When I initially surfaced the table, it took less than .010 to true it up. After I surfaced it, I applied two coats of shellac.
We often use an interim spoilboard under our cuts to minimize through cut damage to the table - its scrap 3mm hardboard. As a result, we don't have to resurface the main spoilboard that often. Crickets chirping, a happy camper... then.... nightfall...
About 3 months ago, we were doing something that was critical for Z work, so I resurfaced the table and it was out by .085 - I was very surprised (actually, I used a different word) So, got it flat, sealed it, went on our way...
Yesterday we were having trouble with the fit of some rabbets/dadoes and lo and behold... Rose figured that the table might be out. We did some checks, decided to resurface and this time we had to mill .095 to bring it true. What the ell is going on? Our metal table is a copy of Wayne Locke's (sp?) and the spoilboard is supported every 12 -18" or so, and the whole thing is sitting on a concrete slab. If any of y'all have seen .18 of some masonite, acting all nonchalant, yet out of place, I'd sure like to know about it.
While I guess humidity could be an issue, all of this has happened in a single season, and I find it hard to believe that 1 3/4" thick spoilboard out of plywood would move over 3/16".
Any ideas?
Thanks in advance...
John
