Have just finished making my vacuum table based upon design concepts I have gleamed over the years as well as on these forums. It works extremely well. Although since I've been racking my brain as well as precious time working out the problems I've been having with my steppers over-stepping that I haven't had the time to experiment. Anyway, my setup consists of running a file that drilled/routed 45 1/2" hole through my first 1-1/8" particle board subtop. Then we ran the same file using a 3/8" bit cutting 45 holes through my second 1-1/8" subtop. From the under side of the table we pressed 3/8" poly tubing (the kind used for refridgerator water line)into the 3/8" holes previously routed, we then trimmed the excess protrusion with a chisel and coated top with a sealant (lac sealer). Clear silicone helps seal the tubing in place although just like the second subtop, I don't think the silicone was really so necessary as the tubing was a bugger to push through. These tubes were to be tied into a copper manifolds via barbed poly "T" fittings. That was until I realized we needed somehting like 45 "T's" at $1.49 ea, not to mention that 45 was more that both local Lowes and one Home Depot had in stock. So instead, I bought 1 piece of 3/4" x 6" x 6" plexiglas, cut it into 4 pcs 3" X 3". In three pieces we drilled two sides with 10 3/8" holes and connected them with one 3/8" hole. The fourth piece of plexiglas has a total of 16 3/8" holes in it (5 holes in 3 sides plus one connector hole)! To put that many holes into such a small space took some figuring but, it worked. So, next we tied all 45 3/8" poly tubes into the (4) plexiglas manifolds and those manifolds were in turn tied into four copper nipples on the main 1/2" copper manifold. On the copper manifold I sweated four shutoff valves (this is so I can have any combination of hold-downs working. We connected the end of the copper manifold to a rotary vien vacuum pump via a 3/8" poly tube. I've been TRYING to make 45-55 4" melamine disks that will have closed cell tape around the preimeters of both sides, but the aformentioned Bot problems are causing me such grief. Anyway, the few disks I do have completed work quite well. With the pumps on you absolutely cannot pick up one up however you can slightly slide it, hmmm, me thinks its the foam sliding.
At only 7sq. inches and pulling 15 in of mercury thats what, only 70lbs holding force? But a rectangle measuring 6" X 14" is both impossible to lift or slide. I too, plan on experimenting with various other forms of sealants.
I personally like Gerald's great idea of soft surgical tubing, am definitly gonna try that. However if my experience with using fom tape is any indication, then just overlapping the surgical tubing should work, and yes possibly bubble gum or tape.
The neatest part of my concept is that I am going to make a file that has the exact placement of all 45 of my 4" disks, i'll svae it as a .sbp file and by running it in preview mode, it will appear on my computer screen then I'll simply run the file I'm gonna cut also in preview mode and Volia, the former file of the "disks" will still be there and I will know which disks to place where...half disks will go where there are close calls. BTW I have pics of my system. E-mail me at jrconca@innernet.net}
JRC
