I have just recently setup a 120 x 60 prt alpha, when attempting to cut a file which has 27000 lines of constant movement on the X,Y,Z (per line)it starts to jump all over the place.
This was on a laptop with 1.8GHZ and 512 Ram, trying to run at 4ips, I switched over to my laptop which has 3.2GHZ and 512 ram and I could run it smoothly at 8ips (both are cutting foam).
Is the calculation to much for the smaller laptop?
or is something wrong with it?
Both jog smoothly at 12ips!!!
I have cheked all of the axis and when not in gear they run very smoothly on the rails.
Is it harder to keep the 60" bridge running smooth?
also I noticed that the "X" motors are running twice as hot as the "Y" & "X" motors, is this normal?
any ideas are appreciated
