The X axis' on our machine are binding and locking up all the way down the rails. It does it if i drive the machine manually or while running a program. The only way i can really get it to go away is when i drive the machine with a speed setting of 1. Anything over that, and the motors will bind up all the way up and down the X axis.
This problem started quite suddenly it seems. There may have been a few times of a little bit of chattering or binding, but it really got bad within a matter of minutes.
I had just finished running one cut program. I moved the zero location to a new one, had everything set up, and started running a new cut program. About half way thru the cut, it started binding up, and now the problem is happening non stop.
any advice.?
