Anybody been using Vfontz, I can’t seem to generate a font higher than 1 inch. I’ve been trying to make 3 inch lettering, but when I hit ‘create toolpath’ it doesn’t make a complete path, some lines are red & some are black. When I alter the ‘tool diameter’ setting to 90 to 120 degrees the toolpath works, but the code comes out really weird and doesn’t follow the depth I put in. If someone is using Vfontz could you post the settings for a 3" letter that works for you. I’ve found another program from FastCam called FontGEN, it converts to DXF and works well with
Turbocad but it doesn’t do the Typesetter affect. http://www.fastcamusa.com/ Thanks Rick
