After the Boise Camp last Saturday I'm all ready to rework my PR and try to get some more performance out of it.
I think the weakest link in the machine is probably the Z axis. I'm wondering if I can install a new Z axis from say Tech Isel or some other company, with an upgrade ball screw and linear bearings, and of course a larger stepper motor.
1) Has anyone done upgraded a PR Z axis?
2) Is the Z driver in the PR controller capable of driving a larger stepper motor- like say a Y axis motor? That is, is the Z driver the same as the rest of the drivers in the PR controller?
3) Will I need to upgrade the Y carriage to handle a 3hp spindle? If I upgrade the Z axis, I'd like it to be able to use a spindle. If I need to upgrade the Y axis to accommodate the increased weight, I'd like to know that now.
I hope to get a bit more speed out of an upgraded Z axis, but more importantly, a little better performance for 3D work and better reliability. Are these reasonable expectations?
Still more upgrade questions, for the patient. I'm considering three more improvements:
1) replace the table base with sheet phenolic- I'm wanting a stable, always flat surface to mount spoilboard or plenum to. Wood changes thickness over the table size, adding to problems with spoilboard thickness. Will Phenolic cure this?
2) Y axis reinforcement- I want to weld triangles into the corners of my Y carriage so that it is much harder to get it to rack.
3) New X rails- I saw an excellent idea to install new hard rails on the outside of the unistrut, such that the bearings ride vertically. I expect this will make it harder to rack the Y carriage as well. ANy input?
All this is because I really want to get reliable performance out of my PR. If I can get that, I can justify a controller upgrade- something like the Acension or maybe a PRAlpha motherboard and Gecko/Mach3. WHo knows. But not until I have the mechanical part working as well as it can.
I'd appreciate any input before I start tweaking things.
Wayne from White Salmon
