I am new to using a CNC and will primarily be using the machine to make frames used in picture framing. Many will be rectangles with an inside edge cut at a 25 degree bevel. Is it possible to get a sharp inside corner on a bevel cut frame using Shop Bot Wizard instead of the rounded corner made by a typical V bit? If not, can you recommend any software that will allow for that type of design?
