I am about to take on a job where I will have to laminate multiple sheets of Extira into 3"thick slabs which will then be cut as "slices" . These slices will then be machined as segments of a file which will be either 9"or 12"tall, and roughly 36 square feet in area.
Since I am a one person shop I will probably opt to use the .5" thickness so I can actually move the sheets around by myself. I'm afraid that .75" and upwards will be a bear. Also since this is going to be VERY heavy in the 3" thick form I willl probably build it right on my table, let the glue/glop dry and then machine the slices. In all I will have either 3 or 4 slices to do this way. As I do the cuts I can knock off surrounding areas of material, and possibly even hollow out some layers to lighten the final piece a bit..
What do I use that will hold Extira quickly and securely? This will be an indoor application so I am not worried about archival assembly materials either. Liquid nails?, Silicone?, Carpenter's glue? Has anybody even tried this yet?
