Results 1 to 8 of 8
Thread: Cutting same part multiple times
    Wilson Fab Works, Lancaster SC
    Default Cutting same part multiple times
    A real newby question here, I'm sure, but have suddenly forgotten the process. I want to cut the same part several times with a set distance between them. I am using Millwizard to engineer the process from a scanned image. Help, please!
    Thanks!
    Bud Wilson
    , South Jordan Utah
    Here's the way that I do it with a 2-D file. Notice that you first jog to the correct locations and then you issue an FP command (don't forget all five commas for each FP command):
    Lenox High School, Lenox MA
    Bill Young has a program "Part File Assembler" that will help you do this. It's on this page http://www.shopbottools.com/BillsCorner.htm
    Jun 2007
    Hampton Roads, VA
    I think the cut and paste moster got you.
    FP, file.sbp.sbp, , , , , 2
    , South Jordan Utah
    You're right. There should only be one ".sbp" suffix per file.
    Thanks to you all for your help. I think that Bill Young's Part File Assembler will do what I need to do.
    Ignorance is no sin, but is a terrible inconvenience.
    Bud Wilson
    Oct 2000
    Willis Wharf, VA
    Hey Bud,
    This article might help too
    http://www.shopbottools.com/BillsCor...rt%20Files%202
    Jun 2001
    Austin, TX
    I have made a simple file something like this:
    FP, whatever file
    M2, Whatever offset
    Z2
    FP, whatever file
    Include as many repetitions as desired in file.
    I know that rezeroing is not the recommended way but it is fast and easy and a C3 when done makes everything right.
  1. Cutting multiple layers
    By mcgoo in forum Techniques for Cutting, Drilling, Machining
    Last Post: 12-02-2009, 06:02 AM
  2. Replies: 3
    Last Post: 11-04-2008, 08:27 AM
  3. Running a file multiple times
    By andyb in forum Developers
    Last Post: 08-06-2008, 09:56 AM
  4. What controls overall cutting times
    By mikejohn in forum Archives2006
    Last Post: 05-16-2006, 12:26 AM
  5. Cutting multiple parts from stacks of laminate
    By rockytops in forum Archives2004
    Last Post: 04-07-2004, 12:35 PM
