Have been asked to quote on a large run of 8" wide gingerbread fascia cut from 1/2" marine ply, Would really appreciate any suggestions as to type of bit and feed speeds - am looking for minimum sanding (read none)after cutting. I have had some problems in the past cutting this type of marine ply with tearout on the face veneer which takes forever to fill and sand. The minimum radius in the rather simple pattern is 1/4" so a 1/2" bit would be ideal for the cut. The top edge of the fascia is straght, the bottom 2 easy joined radii with a heartshaped pierced cutout on 8" centers 2" from the top edge. I have a PRT96 with a good vacuum hold down system so holding the sheets is not a problem. I have a feeling a ply boatbuilder would know about this sort of thing.
