For those that have sliced 3D designs, what are you doing to hold the material while cutting the slices? Does your vacuum hold even with the through-cuts? Are you using tabs? Spray adhesive?
Normally I don't do through-cuts with 3D work, but I have some projects coming up that will require it.
