As I work towards getting a Dual Z installed on my 9660, one of the problems is getting dust collection switched between the 2 axis'.
Here is couple pics of the beta version of a valve that uses a SMC air operated rotary actuator to swap the upper dust hose from the collector between the Z and A dust foot hoses.
The valve will operate using control board outputs into a solenoid valve that will move the valve plate to the axis that is cutting.
Parts were cut from 1/2" solid PVC and 4" OD acrylic tube. Top tube swivels in valve plate as to not kink the hose. Ground wires will be added when permanently installed.
Gary
