I have an order to make 20 small boxes. The boxes are 1.25" thick, 3" wide and 5" long. They are designed for electronic components. The attached screen shot shows the recesses that have to be machined. I'll use a .125 end mill for the 4 narrow slots. However I'm not certain what cutter would be best for the larger recesses. I'd like to use one bit to machine all of the 4 larger pockets. The width of the smallest of the 4 is .5". I cut a sample with a .25 up spiral but I'm debating if I should go to a .375". Also, what type of bit would be best; upspiral, downspiral, staright, straight with shear?
