What is the least expensive software that would allow you to import files as a dxf and v carve Looking at doing signs only.
David if your Bot is a new one then it comes with parts wizzard it alows you to do true type fonts v-carveing the other program I use alot is corel Draw it is cheep and works great for signage. also if you get into vinyl signs that is the letters and logo etc done in vinyl then get a 24" plotter cutter from sign wharehouse they supply a program with their machine called Ve LXI Master and with that program and a Vector Art Mega Collection,you can do just about any 2D signage.the Ve LXI outputs an export in DXF then the Bot can do the designs you create in that program. Sign wharehouse is www.signwarehouse.com
David in Wyoming P.S. Runs about $3,000.00 for the package.
