I just set up a new PRT96. Setup went smoothly and initial test showed that reposition and accuracy is better than the stated spec.
I have observed two behaviors of the tool that I don’t know whether they are normal or need to be fixed.
The first one is that whenever I turn on the control box (it doesn’t matter whether it is turned on before or after the PC and the control software are running) the tool will make a noise (sometimes louder than other times) and x-gantry moves a little (I measured once about 0.01”). I am not sure whether it always moves the same distance or whether Y and Z move too. Is this something I should worry about?
Second, the tool move very quite when “jogging” but make noises when “moving.” This perhaps is normal but if anyone knows the reasons for it.
Any help will be appreciated.
George
