Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Moving My Shopbot
    Mar 2005
    , Alexis Illinois
    In process of buying a used PRT96 w/ steel table. I will pick it up, does any one know or have an idea what it weights. Have large trailer just want to double check to make sure it can handle it.
    Gerald Wilson
    Mar 2005
    , Alexis Illinois
    I got too jump, Shopbot replied and said tool and table weight 928lbs, plus weight of wood for vacuum table, spoilboard, etc.
    Thank You
    Gerald Wilson
    Sep 2004
    Digital Router Works, Farmington Utah
    Some additional info. Luckily prior to building my table, I modeled it up in SolidWorks. Once I applied material properties of the steel, I got a rough estimate of 516# for just the steel. (PRT table, plans circa 2004, but including 4 additional L-Bracket braces). If I add another 60# for plywood base board, fastners, and feet, I'm at about 575#. I think 6-8 guys should be able to move that around. Mind you I'm removing the gantry for this move. BUT, if I have enough help, I might leave the gantry on. We'll see.
    Apr 2006
    Hines Wood Designs, Harrison OH
    Gerald W., you should be fine. I moved my Alpha in the back of my pickup with a standard 6 ft. bed. The rails stuck out a bit (obviously), but since they were wrapped with tons of tarp then banded together it was fine. I didn't have a vac table or spoilboard though.
    Mar 2005
    , Alexis Illinois
    Thanks everyone, should be fine. With this info I know the trailer is more than strong enough. It moved an early 1900's upright piano just a few months back. Can not wait for the trip.
    Thanks Again
  6. #16
    Nov 2010
    Buchanan New York
    Hi. I just picked up a cargo trailer. 3/4" Ply floor. I have a 4x8 Prs Standard. Do you know if 3/4" ply floor 16" OC will suppory the bot? Or should I consider adding an.extra layer to 3/4" Ply floor 16" OC. Thanks for any help. Best. Joe..
  7. #17
    Nov 2010
    Buchanan New York
    Hi All. looking to move my 4x8 PRS Standard using a cargo trailer. it has 3/4'' plywood floor supports are 16" on center. Does anyone know if the 3/4" ply will support the weight? I thought about laying additional ply strips where legs will sit. Thought this would help to spread the weight if needed. Thanks in Advance for your help. Joe.
  1. Moving my shopbot?
    By gundog in forum Archives2008
    Last Post: 04-27-2008, 09:39 AM
  2. Moving a shopbot
    By gerard in forum Archives2007
    Last Post: 11-25-2007, 08:03 PM
  3. Help moving shopbot NC
    By storklady in forum Archives2007
    Last Post: 08-21-2007, 06:05 PM
  4. Moving Shopbot
    By stephen in forum Archives2007
    Last Post: 04-02-2007, 09:49 AM
  5. Moving a 96" Shopbot
    By groover@americanwoodsign.com in forum Archives 2003
    Last Post: 05-26-2003, 03:56 PM
