Decided to upgrade my vac system when I moved my shop. Upgraded to a Becker VTLF250 from a 10hp Fuji. I cut 3/4 melamine almost exclusively.The fuji had done great at about 7"mg and degradation to about 5.5" after cuts on most sheets. The only problems I had was on very small pieces, ie 12"X3.5" toe-kicks.
The problem I am having now is very quick loss of vacuum. All plumed up and cutoff valve closed I get 24". With a full sheet of melamine loaded it drops to 8". I have 4 zones. If I open only 1 zone I can maybe get to 10".
The worst part is when cutting vac drops rapidly.
I know that I must have some serious leaks. I have resealed the edges of the spoil board with caulk.
I have gone around with burning incense (saying all sorts of incantations) and seeing no major leaks.
How much should I normally see with a full sheet?
(On the fuji the relief valve kicks in.)
How much should it degrade with cutting?
Any notorious places to look?
BTW my plenum is made of Azak so sealing there should not be a problem. Spoilboard is caulked to the plenum.
Bob
