As I mentioned in a previous thread, I use AutoCAD to prepare detailed plans of what I intend to build in the shop. This has worked well for conventional wood working, and I am assured that I will be able to apply these skills to use with a ShopBot.
I would like to know if there is anything to be aware of when designing for the SB. I have a pile of designs that I think would lend them selves to production on the shopbot. I also intend to get some more SB specific ideas worked out, and designed with ACAD. I have figured out about bit radius, and how that effects inside corners. That’s no different from the limitations I presently have when using pattern bits on a table router. What other less obvious pitfalls await me?
Do the files go right from DXF to the SB cut list software? Does it look at just one perspective, or will it know what to do with a three dimensional file? (Assuming only the software that ships with the SB, not any of the 3D stuff) Will the stock SB software be able to make sense out of a 3D DXF file and convert it to a 2.5D cut file?
I’d hate to waste my time designing stuff specifically to run on the SB, only to have to do it again because I missed some critical criteria or data point.
Once again, thank you for entertaining my questions as I think-out-loud about a future SB purchase.
