Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Architechtural woodworking
    rgbrown@itexas.net Guest
    Donn,
    The "trick" is to figure out the geometry of the piece being created. Then one needs to deduce the angles needed to cut that geometry, obtain the bits, create the cutting files and go from there.
    There are some programs that are said to figure these paths though I don't know of any. I have modeled both raised and inset cutting in RHINO and have been happy with the results. The method I use takes considerable time.
    Ron Brown - rgbrown@itexas.net
    If Stupidity got us into this mess,
    then why can't it get us out? - Will Rogers
    Aug 2003
    Amelia Island, FL
    This forum has been extremely helpful in other areas. Now, I have some questions about creating custom moulding with a PRT. Unfortunately, my schedule prohibits me from attending the NJ Camp ShopBot this year. I would love to visit Marshall's Millwork! I can't, so here are some of my questions.
    1) What size and type of mouldings are typically produced for architectural woodwork? Are the normal pieces chair rails and crown moulding? What other types of pieces are requested by customers? Yes, I looked through Marshall's website... Beautiful pictures!
    2) What size, type, and grade of raw materials are used? For example, If I am carving 3D raised moulding, what thickness of stock is typically used? Do customers typically stain or paint the finished product?
    3) What lengths of moulding are typically produced? I may need to rearrange my shop for a better PRT location.
    4) What software is typically used to produce this work? Are there 3D files containing these items that can be purchased? If so, any pointers?
    5) What are typical pricings for this work? Are there separate pricings for computer work, setup, tooling, and actual production? If so, could someone share some estimates?
    6) Who are the typical customers? General Contractors? Architects? Designers? Homeowners? I.e., where should I concentrate my marketing?
    If any of these questions are too sensitive to discuss on the forum, I would welcome private discussions offline also. The purpose of my questions is NOT to undermine anyone else's business. Rather, I am in the process of constructing a business plan for my business and am gathering information for my business' success. I do NOT want to be one of the people who has to sell their PRT because they couldn't make the business work right.
    Thanks in advance,
    Charles
    bjwat@comcast.net Guest
    Charles,
    You bring up a lot of common questions regarding doing 3D moldings on the Bot. I'll add in my $.02 here and what I have found.
    It's important to note that the Bot isn't always the most efficient tool for the job. In other words, a molding machine with cutting knives is a much better choice, if what you need to do can be found in a knife profile. It takes about an hour per foot to do 3D moldings depending upon Z moves which slow down the process.
    Poplar is a nice wood to use if the customer is going to paint it. I try to focus on just cutting materials and for the most part, refuse to paint or stain carved items. I have found that there is too much room for error and I don't want to be bothered with color matching and all of that.
    Length is dependent upon what the customer needs. If you want to make a 12' molding in 3D, you'd have to charge your hourly rate * 12...if you are doing a custom job and you can't get that profile from any other source, then a price of $300 or so isn't such a shock if the customer has to have it.
    Software...ArtCAM comes to mind for this type of work. I've seen the rep extrude molding profiles in minutes. I don't do a lot of 3D stuff, but I have been pretty successful with Rhino 3D and MillWizard.
    Hope that helps,
    -Brady
    PS- Don't ever sell your Bot...Just think of new products to cut out with it
  1. 4x4 or 4x8 PRS for woodworking?
    By bsouhlal in forum ShopBotter Message Board
    Last Post: 10-03-2012, 11:58 PM
  2. some different signs and woodworking
    By knight_toolworks in forum Folder 2010
    Last Post: 05-14-2010, 02:24 PM
  3. Woodworking link
    By paul60 in forum ShopBotter Message Board
    Last Post: 01-16-2010, 05:06 PM
  4. The Woodworking Shows
    By coolhammerman in forum Archives2007
    Last Post: 10-16-2007, 09:10 AM
  5. Woodworking suppliers
    By jthelen in forum Archives2005
    Last Post: 02-12-2005, 03:05 PM
