Results 1 to 10 of 20
Thread: Which Post Processor?
    Dec 2008
    , Friday Harbor, San Juan Islands Washington
    Default Which Post Processor?
    I have updated to the latest Aspire patch but can't find the post processor for my ShopBot when saving toolpaths. I tried saving as: Inch/Arch with tool changer and speed control. I use to save using Alpha, inch with speed control but it doesn't appear in the list of post processors in the new Aspire. I have an Alpha, spindle with speed control. Is this the correct post processor? When I go to cut a file it sends the cutter to cut 3/4" above the material! I have never had this problem before. If that isn't the problem what can make my Bot want to cut above the material? I have redone setting the Z axis to material more than once but it doesn't seem to be the problem. Any suggestions?
    Jan 2006
    Un-Employed Westminster, Ca
    If Aspire does the same thing that my V-Carve Pro did, all your original Posts were moved.
    Look in the Program Files/Aspire/PostP sub-directory for another sub-directory named ShopBot_orig. All your PostP should be in there.
    Move the file you want up into the PostP directory.
    Oct 2006
    WildWood Mfg.., Ulm Montana
    Daryl
    Open the file and make certain that when the bit begins to cut, the numbers should be a negitive number. (M3,5.0000,3.0000,-0.125)
    If the number is (M3,5.000,3.000,0.6250) then the file is set to cut at the table.
    But I always copy the Post Processor I want to use into the 'Program Files/Aspire2/Post P/ShopBot_org' I have modified a couple of Post Processors, so I always copy the modified PostP when upgrading VCarve and now Aspire. (As Roger said)
    Dec 2008
    Butch and Roger, thanks for the response. I read Aspires site and see what may be my problem with the post processor. As far as cutting too high may be what you say, it was set to cut from the table. I will check that possibility out. Thanks again
    cnc routing, portland or
    they kind of flubbed on them. the inches arcs with spindle speed control the new one reads as scott w when in aspire. I opened it up and saw the goof also it says this file was created by someone else (G) a little editing fixed it up.
    Dec 2008
    Butch, you were correct. The file was written off the table. I didn't see the mistake but did fix it. Steve what do you mean the new post processor reads "Scott W". Is that the post processor's name by mistake? How did you open it to find out??
    Sep 2009
    Surrey, UK
    The Post Processors are just text files. You can use Notepad or any other editor to open them.
    the physical file name is right but when you look at it under aspire it has the guys name. yes you use a text edit app. you can your name to it so it adds it to the toolpath and such.
    Sounds like you guys may have somehow got hold of a modified .pp that I may have sent to Vectric years ago for some reason that I can't remember now. ;-)
    Be careful of some of those new ShopBot posts as the one I tried (for testing purposes) makes the z start moving down to z zero as it jogs to the start point. Could cause some problems if you have some clamps in the path that you need to clear. It doesn't matter if you use the new Z1 and Z2 system in Aspire/VCP because its not enabled in the post.
    Scott W
    Oct 2009
    Tonasket, WA
    What do you guys mean when you talk about "Post Processors"?
    I've heard this term often but have no idea what you are talking about.
    Are these notes about cutting the file written by the creator of the file?
  1. Arc post processor
    By Davo in forum ShopBotter Message Board
    Last Post: 03-12-2015, 10:16 PM
  2. Post Processor in CPP 8.7
    By terryjones in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 11-23-2014, 08:30 PM
  3. Post Processor
    By magickpurple in forum ShopBot Desktop
    Last Post: 07-24-2014, 11:38 AM
  4. Post processor ?
    By dvmike in forum ShopBotter Message Board
    Last Post: 11-26-2010, 04:55 PM
  5. Art Cam Pro Post Processor
    By carl in forum Archives2008
    Last Post: 05-23-2008, 09:08 AM
