Results 1 to 10 of 10
Thread: Supplier of generic plastic
    Jun 2005
    Default Supplier of generic plastic
    Hi All,
    I am looking for plastic sheets that are 3/4 inch thick to be used for making tap handles for a brewery. As a test, I tried using leftover King Starboard plastic and it works great, but it's pricy and doesn't come in the colors I need.
    Here are the specifics that I need:
    - It needs to be in a sheet format, up to 4 ft by 8 ft
    - It needs to be 3/4 inch thick.
    - In needs to be available in red, white, and black, and all glossy
    - Of course, I'd like to be easily "machinable"
    Does anyone have any suggestions on where I can get something like this? I can do the fancy plastic route like King Plastics if they have the colors, but it seems like overkill to pay for stuff I don't need, like UV protection, etc.
    Thanks.
    -Keith
    Jan 2011
    Buchanan Michigan
    Keith, I get my Lexan, PVC and UHMW from Grainger but in clear, smoke or white. I dont know about your need for red and black.
    Jul 2005
    Brookline, New Hampshire
    I'd also lean toward Polycarbonate (Lexan) However ...
    1. A 4' x 8' sheet will be very heavy (~200lbs)
    2. It could cost $2K + shipping
    Paul Z
    Feb 2011
    Yeah, anything you get that thick is going to be expensive & heavy, really a specialty item.
    I have an acrylic supplier local to me who has everything you could imagine and more, if you'd like to chat with him pm me and I'll give you his number, real nice and helpful guy.
    Not necessarily for any ordering, don't even know if he does mail orders, but more to pick his brain about possibilities.
    Jan 2014
    Spring Hill, KS
    Keith,
    More than likely you are going to need to buy your material locally, especially at that thickness shipping will kill you. We purchase a large amount of Plexiglass from Laird Plastics and they have a number of locations throughout the US. We also use E&T Plastics as well as Regal Plastics. I would google all of those suppliers and see if they can supply what you are looking for.
    As for the "glossy" and "machinable"...Glossy is usually a buffed polish or a flame polish applied/performed after the machining. Unless I am wrong, which would only be the third time today.
    Enjoy,
    NTraub
    For the color you are likely to end up with Acrylic rather than Starboard type HDPE. 3/4" in colorthrough is EXPENSIVE.
    Apr 2001
    South Elgin, IL
    You might check into Azek PVC also. Depending on the machined shape though, it may not have the strength you desire. You could paint the colors with a plastic paint or have a body shop do it.
    If you have sufficient quantity of parts, the best way would probably be injection molding.
    May 2005
    Londonderry New Hampshire
    Kleer Lumber comes in boards and sheets - great stuff!
    Dick
    Aspire 10.5
    Jun 2012
    Philadelphia
    www.totalplastics.com , they have a few branches, it actually turned out that the majority of the places I was buying plastic from are getting it here first, obviously cutting out the middle man is great and I can buy whole sheets for the same amount as i was paying for pieces.
    Have you thought about solid surface material.
  1. Canadian Supplier
    By GlenP in forum Product/Supplier List and Requests
    Last Post: 11-18-2012, 12:14 PM
  2. Router bit supplier
    By phil_o in forum Product/Supplier List and Requests
    Last Post: 02-25-2012, 10:40 AM
  3. Custom Bit Supplier
    By Mark Farris in forum Product/Supplier List and Requests
    Last Post: 01-24-2012, 09:50 PM
  4. pinion supplier
    By fozzyber in forum ShopBotter Message Board
    Last Post: 10-08-2011, 11:01 AM
  5. Metal supplier in NC
    By blackhawk in forum Product/Supplier List and Requests
    Last Post: 02-18-2011, 09:55 AM
