So, I originally was following the black box thread and talking about my plans but then that thread got closed, so I thought that I would post my results here.
Around Christmas I decided that I needed to update my machine to incorporate a vacuum hold down. I just got tired of screwing everything down and all of the inconsistencies that come with screws. So I rebuilt my stand to allow for vacuum plumbing and sheet good storage underneath.
Also I decided to go with a variation of the plenum from I believe one of Chris Brady's designs
During this process I started searching for ideas to do this vacuum system cheaply and ran across the black box thread which discussed some ideas and most importantly vacuum motor options. This is what prompted me to order the LH7123.
Where my design differed is that I didn't like the idea of having a large vacuum box on the ground taking up space, so I decided to make my box a little more compact and just hang it off of the end of my table.
As usual I didn't do a great job taking photos to show all of the design, and I actually don't have a real 3D model to show you guys (I just drew it up in vcarve and used my brain to do the 3D part), so I will just do my best to describe it.
Basically there is a back plate that I can bolt to the end of my machine that faces the garage door, and corresponding holes in my stand that lead to 2" PVC pipes routed to the 4 zones in my table plenum. Each zone has a gate valve up under the table right behind where the vac box attaches.
Back plate in place
This was all routed out of 3/4" melamine that a friend sold me cheap b/c it was a maple wood grain patter that he no longer liked. I plan to paint it all in the end so it was a good deal.
I test fitted the back plate and all was well, so I glued up the vac box and glued it to the back plate. The vac box is 12" from back plate to the lid where the fan holes are located. Around 4" of the vac box is plenum that all of the motors will share which is also connected to the stand plumbing via PVC couplers which are cemented to the back side of the back plate. The remaining 8" is dedicated to the motor housing and lid.
Picture of the vac box plenum from above
Continued on next post...
