Results 1 to 6 of 6
Thread: File Naming Strategy
    Nov 2016
    New Mexico
    Default File Naming Strategy
    Just wondering what kind of File Naming Strategies are used by others.
    In our case, we use this:
    bit-subject-time
    60- A 60 degree V blade
    Subject - An identifier of the work piece
    Time- Amount of time to cut the piece
    So... A file name for a John Wayne sign cutting with a 60 degree V bit and taking 45 minutes to cut would be:
    60-JohnWayne-45.sbp
    Aug 2013
    Clayton, NC
    I start with the project identifier name, and then a version number.
    Like "NC Coffee Table V1"
    "NC Coffee Table V2" and so forth.
    Daniel E.
    Porter Cable Router
    Vacuum Table w/ 2 Fein vacs
    Aspire 9.0
    Mar 2016
    Brooklet, Ga
    For my drawing files I'll do something simple like "Elephant bookshelf".
    For the toolpath files, I'll do something like this:
    Elephantbookshelf.50ply48x96Pocketandprofile.25com pmortTableZero
    This tells me:
    1- what I'm cutting
    2- what material I'm using, how thick the material is, and what the size of the material is that I need
    3- what toolpath it is cutting
    4- what bit I need to use
    5- where to zero the Z.
    If I need to use multiple toolpaths and different bits on the same job, I edit #3 and 4 when saving toolpaths in Vcarve Pro to let me know what I need to do next on the same sheet.
    Labeling the files this way lets me know what I need to know if I need to do a job I've done before if I'm away from my design computer.
    2006 PRTalpha 96x48
    3hp SEV spindle
    Vcarve Pro8
    Nov 2016
    New Mexico
    Wow. That makes sense. Will rethink my strategy for file names.
    Feb 2004
    Rogers, Arkansas
    For toolpaths I use:
    A_jobname_60hsv_Zll_Top
    A is order toolpaths are to be cut in (A,B,C etc)
    Jobname is a job id
    60hsv is the bit to be used (60 Hersaf V, 1_4em for 1/4 End Mill etc)
    Zll is z lower left (Zcent would be z center of material)
    Top or Bot for top of material
    Ken Zey
    Rogers, AR
    www.CedarSlabSigns.com
    www.lookoutmercantile.com
    www.digitalmillwork.com
    6x12 PRS alpha
    Jun 2004
    Springfield Mo
    Default tool paths
    I like the zeykr system ... with a tool path note for material size and three numbers for the cutting depth
    sp is a spiral toolpath... tb means tabs are added to the final cut
    hp is home position
    files are cut in the order shown A to V
