Results 1 to 5 of 5
Thread: Circle Center finder
    Aug 2001
    Belle River, Ontario
    Default Circle Center finder
    Hi folks.
    Was wondering if anyone has created, or knows a way to write to SB part program to find center on a disc/circle.
    I want to utilize a touch plate on both sides of a circle in x axis and a single touch plate in the +y axis. Framed on 3 sides
    My thought was to run a XYZ_Zero program that zeros Z first, then moves -x till contact, moves +x until contact, Does the math to locate center, (while retaining the value), moves x axis to center of the two values , then move +y until contact, applies the retained value from the x axis math to the y axis and moves y axis to the center of the circle.
    Anyone able to assist me?
    Thank you
    Oct 2000
    Willis Wharf, VA
    This is kind of the inverse of what you want, but there's a file that's installed with the ShopBot software that zeroes to the sides of a hole instead of the edge of a disc. It might be a good starting point though, and be modified to do what you want
    You can find it in your SBParts folder on your C drive, and it's named "sample_Center_inHole.sbp"
    Bill
    It's been some time since I've used it, but I used to use this with a plate for inside/outside corner finding/setting. You should be able to dissect it and reconfigure for your needs.
    https://1drv.ms/u/s!AsPqyLrhnhkRgbop...fJ43A?e=1iRcA7
    Aug 2001
    Thank you Bill, for a reminder of a file I had long forgotten.
    Thank you Scott, I look forward to checking out this file and seeing if I can massage it for my intentions.
    All the best to every SB'er here.
    Aug 2001
    Once again, thanks to all who gave me guidance on this project. I now have a part program that finds center of a circle after 3 point contact.
    Appreciate everything.
