Results 1 to 10 of 14
Thread: Warped HDU Panel
    Norman, Ok
    Default Warped HDU Panel
    Greetings troops,
    Here's a 10' sign panel Ron and I completed a couple of weeks ago. They we so impressed they placed an order for another one. But there's trouble! Last Friday I made a trip over to take some photo's and to my horror, the sign was warping! The sides had curled up a good two inches and the top was well on it's way for the same distortion. That spoiled my weekend.
    Here's the problem. We installed this sign panel two weeks ago. It's made from 15lb Signfoam, which is extremely good, but I made the mistake of epoxying a sheet of DiBond to the back. That was down right stupid. The aluminum is expanding much quicker than the HDU. The result is a panel that's curving tword the front by three inches. I'm sure in a month it will be even worse
    Here's my plan of correction. With the panel back in the shop I'll see if I can flatten her out and buzz off the aluminum back. Then I'll apply some 2"X6" cleates. What a mess.
    Here's also a little double sided hanging sign. I'm making it from Cypress. That wood sands better than any wood I've used and holds detail almost as well as HDU.
    May 2005
    , Gladstone Michigan
    Not only do you do some of the most beautiful work I have seen. You also stand behind the work you do. You are a blessing to anybody you come in contact with.
    Dan
    May 2010
    Plano TX
    Joe here is the problem. Its caused by unbalanced panel.
    What does that mean, if you look at section of plywood you gor odd number of layers each layer at 90 deg to next (grain) that balances panel.And forces equalize.
    If you apply laminate to one side of particle board you need to glue backer on other side other wise will warp just as your sign. glue upSame principle applies to wood glue up, what I tell new born wood workers you need to glue up heart to heart, bark to bark.
    I hope that explains balancing.
    This is common practice in woodworking.
    100% MADE IN TEXAS! It's not part of China partner.....
    May 2010
    Chardon, Oh
    One possible solution you may try is put the sign on your machine and cut pockets in the Dibond to create a frame or skeleton effect. This may help lessen the tension or grip on the panel.
    The problem isn't the Dibond, but the adhesive between it & the HDU. If you lay down strips of adhesive (like 1/4" beads) instead of slathering epoxy all over the sheet, you will give things some room to expand. I just talked to an HDU manufacturer yesterday about this very issue. He recommended laying the adhesive in strips.
    I'm not a big fan of silicones for adhesives, but if you have a brand that you know & trust, it's elastic properties can be exploited to give the lamination some room for expansion.
    Jun 2004
    Springfield Mo
    Default Cypress
    Joe,
    What is your source for the cypress ?? What sizes are typical ?
    Thomas,
    Would a mdf countertop with laminate/ warp if was mounted vertical rather than flat ?? How would you prevent that ?
    Norman, Ok
    Curtis,
    I have several wholesalers to purchase from. My local favorite is Phoenix but most of them want you to purchase a volume. My last order was for 12 quarter, which I've stickered for a year. It's rough cut and cost $7.00 a bd foot. I think you can beat that price.
    I've drifted away from Poplar and want to give it another try. Has anyone been routing this material?
    Brady,
    NO, silicone in strips won't work. As you know silicone is air dry and sandwiching it between two non breathing surfaces is asking for trouble. I'd like to see some examples.
    As you know I show samples of just about everything I do and don't ever give recommendations without a first hand knowledge. I've been led down too many dead end trails to listen to sales people.
    Jul 2009
    Harbour Grace Newfoundland
    Joe I,ve router poplar very nice wood I have some out side .With that said its classifed as a hardwood I'am not shure about exterior sign work
    One of the easiest woods to work with in terms of holding detail
    Your sign I have no clue why it twisted just a guess but I suspect rough lumber not dried has a mind of its own bad luck
    Mar 2008
    Radford VA
    Joe - I would not recommend poplar for exterior signs. It is one of the least rot resistant hardwoods. I used some 1X6 boards to dress up a post on my porch. Within about 5 years, I had to replace them because of rot. I had even primed all sides. After about 2 years, I had one poplar board that had started growing a mushroom, no joke.
    Norman, Ok
    Brad,
    I certainly appreciate your savy experience and advice.
    Do you think it would last better if it was treated, to cut down on the micro organisms that turn the wood to pulp? I believe this serious ailment is known as dry rot. I was concerned about this with my use of yellow pine but I found a good solution. A google search brought me to the Univ. of Michigan, Forestry Dept. They suggested there wasn't anysuch thing as Dry Rot. The deterioration of the wood from inside was micro organisms, muching away. One of their recommendation was a wash down with Boric Acid. I've been using that on my Yellow Pine signs for two years. So far so good.
    All that said, it seems I remember a poplar outside sign or two and it had a tendancy to crack and split not to mention warp. I gotta give this wood a try.
    Thanks again for the good advice and I'll tread slowly.
    Joe Crumley
    www.normansign.com
  1. Tiling/Surfacing bow out of warped slab?
    By scottp55 in forum ShopBot Desktop
    Last Post: 07-14-2014, 02:31 PM
  2. Anyone straightened a warped Z plate-Perfectly?
    By scottp55 in forum ShopBotter Message Board
    Last Post: 02-03-2014, 09:57 AM
  3. Warped Boards - How to Straighten them Out Online 12/4/2013
    By TJ in forum Camp ShopBots/User Groups/Training Classes
    Last Post: 12-06-2013, 01:53 AM
  4. Rollers slightly warped
    By angelosart in forum ShopBot Buddy
    Last Post: 03-29-2013, 12:49 PM
  5. Warped
    By joe in forum Sign Making
    Last Post: 04-18-2012, 11:02 PM
