Jeff- changing tools in the middle of a toolpath is not how its intended to work. Output each toolpath to a separate file. Run the first bit operation to completion. You can combine toolpaths that share a bit, with some caveats. For instance dont cut the parts free of the main material before you do the internal operations.
I label each file with the name of the bit and the order it comes in the sequence:
1 QEM T CutPockets.sbp
2 V120 T CutLetters.sbp
etc
Meaning: (1) first operation (QEM) quarter inch end mill (T) zero on the top
Then: (2) second operation (V120) 120deg V bit (T) zero on the top
etc
Its unusual for me to use more than 2 bits, so just 2 or 3 SBP files do everything. As often as I can I try to do an entire part with a single bit, solves the problem entirely. Sometimes that isnt possible or practical tho.
DO NOT exit SB3 or turn off the shopbot between cuts! That will lose your X and Y position. Dont re-zero them beween cuts either. That allows the bot to make the various cuts at the exact location relative to other cuts the way you designed in PartWorks.
If there is a better way to do manual tool changes, Im sure someone will chime in.
Good luck-
D
--Greg Westbrook
