Page 10 of 18 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 179
Thread: Black Box Vac Source
  1. #91
    Jun 2010
    Edmonton, Alberta, Canada
    Default And more pics
    last 5 pics
  2. #92
    Jul 2011
    Atlanta, GA
    I noticed the Lighthouse vac motors require a 1/4" hole (per motor) to allow leakage for proper cooling. Do you guys put (2) 1/4" holes in each chamber of the vac motors or do you put (4) holes in the plenum?
    Paul
    PS. I just ordered (4) of the LH 7123
  3. #93
    Jun 2007
    Sadieville, Kentucky
    Greetings, Paul
    I used a 1/2" ball valve in the manifold to allow bleed air into the system for the times when I cut material that allows me to get a perfect seal. With a perfect seal, the vacuum drops 1 in.Hg when the bleed air valve is fully opened. I installed a sintered bronze muffler on the valve to help with noise and to ensure that nothing gets sucked in. Most of the time I allow the motors to breathe a little by leaving a gap in the vacuum mask around the part that I am holding. I like the valve idea because, depending upon what I am holding, it gives me the option to leave it closed, open it part way, or open it all the way.
    Kind regards,
    JIM
  4. #94
    Jul 2011
    Atlanta, GA
    Thanks Jim, I'll try that approach. Where did you get the bronze muffler?
    Paul
  5. #95
    Jun 2007
    Greetings, Paul
    Grainger sells them in various sizes. I used a 1/2" NPT muffler.
    Kind regards,
    JIM
  6. #96
    Jun 2010
    Paul: Good question, I didn't know about that.
    Jim: That looks like a good idea.
    I believe there's probably enough leakage in my system to equal the flow through a 1/4" hole per motor. Guess I'll know if one of the motors burns out. I do have a separate 2" valve that I open when starting & stopping the motors though to reduce the load at startup.
  7. #97
    Jul 2011
    Atlanta, GA
    Jim,
    Thanks for the link.
    Daren,
    The 1/4" hole per motor is mainly for cooling the vac. I always have wondered if I had enough leakage in my system so that I wouldn't need the seperate holes. I wonder if anybody has figured out how much leakage there is by gauging how strong the vacuum reading is? To better explain... If you have 10"hg of vac and that is the max this motor is capable of, then there would be 0 leakage. But if you're reading 9"hg of vac, then that equates to "blank" leakage? (I'm not smart enough to figure that out)
  8. #98
    Jun 2007
    Greetings,
    I used a 1/2" valve because the area of a 1/2" circle is the same as the sum of the area of four 1/4" circles. In may case, I read 11 in/Hg with all motors running, all the zones valves closed, and the with the bleeder valve closed. When I open the bleeder valve all the way I read 10 in/Hg. If my part/sheet hold down is leaking and I read 10 in/Hg then I don't open the valve because I figure the motors are getting a little air which appears to be a loss of 1 in/Hg. Not very scientific, but it seems to work for me.
    Kind regards,
    JIM
  9. #99
    Jul 2011
    Atlanta, GA
    Good idea Jim. It may not be scientific, but it seems perfectly logical to me
  10. #100
    Sep 2005
    , il
    Default black box
    Hi ,I would like to make my first vac table. I love the black box that has been made. can any one send me the files. thanks alot larry
    kilian55@comcast.net
  1. Wanted: Colorcore Black/white/black
    By WMNH in forum For Sale/Wanted - ShopBot-related items only
    Last Post: 11-02-2016, 08:37 AM
  2. Black Edgebanding Help
    By FJ Baker in forum ShopBotter Message Board
    Last Post: 04-04-2013, 03:50 PM
  3. Black Box Computer?
    By Gary Campbell in forum Variations & Modifications of ShopBots
    Last Post: 08-05-2011, 07:14 AM
  4. Need source for small piece of black ABS
    By kfitz in forum Product/Supplier List and Requests
    Last Post: 02-17-2010, 08:20 PM
  5. BLACK MDF
    By woodworx in forum ShopBotter Message Board
    Last Post: 07-31-2009, 10:18 AM
