Results 1 to 4 of 4
Thread: stolen stool
    Jun 2011
    Amsterdam
    Default stolen stool
    Being inspired by: http://www.kickstarter.com/projects/...rocks?ref=live
    I decided to make it customizable:
    If you use a real browser (tested in latest Firefox & Chrome) you can experiment yourself at http://www.iscriptdesign.com and select projects->iPath -> stool
    customize by adjusting the sliders and when at your liking press dxf export (There is still an issue with the location of the '+' in side the seat) and start routing. Have fun!
    Disclaimer me (the author) nor the owner of this forum can be hold responsible for errors, omisions or any disfunctioning of the provided template and software. Double check your dimensions start out with low cost materials before proceeding with more costly materials.
    Jeroen,
    Very cool. I went to your site and fiddled with it a bit. Because it is in mm i didn't know what i was doing however i made one and downloaded. I'll load it up in my dxf viewer and see how it goes. Always good to have tools like this at our disposal. What is the possibility of making it in Imperial measurements?
    Good Job!
    Words of Wisdom:
    Jun 2011
    Amsterdam
    Thanks for the suggestion! that's what happens if you showcase it in the states :-)
    I tried adding a scale factor in the template but that makes the sliders in the template more or less useless as the slider boundaries and values remain unchanged. 200 mm is not 200 inches. I'm thinking hard about a more mature solution, and let you know!
    Jun 2011
    Amsterdam
    The stool template has now a possibility to toggle its unit of measurements either in mm, cm or inches. Apart from the display value of the sliders nothing changed. So be aware that if you try to edit the file all the parameters are still in mm's. This holds also true when you change a slider in a text or (digit) field.
  1. O/T Nitro funny car operation stolen last night
    By pro70z28 in forum ShopBotter Message Board
    Last Post: 03-14-2011, 09:20 PM
  2. a silly little stool.
    By knight_toolworks in forum Folder 2011
    Last Post: 01-27-2011, 12:01 AM
  3. Stolen Shopbot Link Dongle
    By davebryant in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 08-26-2010, 12:24 PM
  4. A quick stool.
    By knight_toolworks in forum Folder 2009
    Last Post: 07-08-2009, 09:47 PM
  5. Step Stool
    By handh in forum ShopBotter Message Board
    Last Post: 02-09-2009, 09:52 AM
