Results 1 to 8 of 8
Thread: Ripple
    Jan 2012
    Tallahassee
    Default Ripple
    This was one of the first 3d carvings that I did with the ShopBot. I started with a white and black gradient image in photoshop. Then I created a surface in rhino 3d by using the image height field. I created tool paths and sat back for about 10 hours while the machine did its thing.
    It is a maple shelf that I found in a building at FSU.
    There was A LOT of hand sanding afterword. I then finished it with teak oil.
    You can see more photos here: https://www.facebook.com/media/set/?...e=3&uploaded=1
    Also see some of my other work: https://www.facebook.com/NZBSculpt/photos_albums
    Thanks for looking
    Feb 2010
    SOUTH CENTRAL COLORADO
    Default Finish
    I like the finish. Now that you have it done what will it be used for?
    Feb 2013
    New Berlin IL
    what grit sandpaper did go down to... looks more than 180 to me.... 220? 600??
    looks good
    Jan 2012
    Tallahassee
    Quote Originally Posted by cowboy1296 View Post
    I actually gave this to my mom for Christmas last year. It was an initial test. I want to scale it up to something much larger.
    Jan 2012
    Tallahassee
    Quote Originally Posted by Keyco Wood View Post
    looks good
    I believe I took this to 220. It was rather dense maple and I ended up using one of those triangle finish sanders. I wanted to take it to 400 but it took so long for 220 that I just called it even. In the future I will plan my tool paths and tooling more precisely to cut down on sanding time (go with with grain).
    Feb 2010
    Default Use
    I saw something like this that was used as a particians between sections of a restaurant in Alberta Canada. Instead of ripples i think that it was mountains but still a nice addition.
    Might be kind of tough to keep a tea cup from spilling but the quality of the carving and finishing is excellent!
    Words of Wisdom:
    Dec 2011
    Piedmont, SD
    A very cool rendering that looks like drops on a liquid surface.
    Thanks for sharing - truly inspirational!
    Jeff
  1. ripple marks along the x axis
    By Michael Zanzano in forum Spindle and Router Mounting
    Last Post: 05-25-2012, 04:55 AM
