Originally Posted by
bradywatson
If the only purpose of the Sintra is to protect the mirror, then I would just get a 12 or 24" roll of transfer tape, which is like masking tape, available through sign supply houses & cover it with that. It's cheaper in the long run. I don't know how you are attaching the Sintra to the mirror - ???
Sintra cuts beautifully on these machines with a single or double o-flute. So it isn't an issue with the right geometry. You can get by with an end mill, but the finish is not as nice.
FYI - ShopBot has techs in your area that can give you training and tune up the machine in your shop. Call them to inquire. 2 days of training would pay for itself in no time considering you'd be 'getting all the answers' to your questions right away.
Your 300Hz spindle is fine. It's nice to have a few extra RPM, but there is no impediment to you cutting what you want.
You don't want to use a BALL end mill - if for no other reason than you will be left with a cusp on the parts that looks like this---> л - which is probably NOT what you want. You could get around this by burying the bit into the table until it no longer imparts a cusp on the edge, but this is frowned upon for a number of reasons.
