Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Chair seat carving: Probe or Aspire?
  1. #31
    Jul 2011
    Timmins, Ontario, Canada
  2. #32
    Jul 2011
  3. #33
    Jul 2011
    Here is a better shot of the finished rendering.
    If I am doing a set of seats I usually trial cut one in a blank of poplar or something cheap, and sit in it to make sure the proportions are correct. After a few seats you can usually get pretty good just on the screen.
    One thing, with the sweep, the carve gets deeper in the rear section where your butt sits, and shallower in the narrower section where your thigh is, and deeper again at the front edge. Just like you want it to be.
    I also sometimes round off the front section with more 3D manipulation, but generally find it faster to just pass a roundover bit with a hand held router (with the base sitting on the front edge of the seat, while clamped vertically in a bench vise).
  4. #34
    Jul 2011
    And usually, with my 5/8" Onsrud spiral carbide ball end mill, and a stepover of 5% to 7%, I can forgo the roughing pass and just carve the seat going back and forth starting at the rear and working side to side, and ending along the front edge. That way you start with a very light cut and get progressively deeper.
    Just hit it with a 120 grit disk in a random orbital and you are good to go!
  5. #35
    Jul 2011
    Quote Originally Posted by blackhawk View Post
    Andrew - I am still interested in your method. If you could still help out, it would be greatly appreciated.
    Brad did this help you at all?
  6. #36
    Mar 2008
    Radford VA
    Andrew - Yes, I think that I have it. Great write up! I read your post twice through and in about 15 minutes created one of my own. Take a look below and see if it looks OK to you.
  1. Aspire file for carving a seat
    By dlcw in forum ShopBotter Message Board
    Last Post: 08-19-2011, 11:16 AM
  2. Chair seat
    By woodteacher in forum ShopBotter Message Board
    Last Post: 06-02-2011, 10:26 AM
  3. Fitting a chair with a v-carving (for Jack J)
    By henrik_o in forum Folder 2008
    Last Post: 10-10-2008, 06:14 PM
  4. Chair seat contours
    By andre in forum Archives2007
    Last Post: 06-03-2007, 02:13 AM
  5. "scooping out" a chair seat
    By edcoleman in forum Archives - 2005
    Last Post: 09-30-2005, 02:43 PM
