Results 1 to 9 of 9
Thread: Despite the cheery music, this is why I dislike cutting PVC
    Apr 2001
    South Elgin, IL
    Default Despite the cheery music, this is why I dislike cutting PVC
    https://youtu.be/gcRzYlEdyic
    Dust removal would help but the static issue is a problem for my set up.
    I have cut pvc only a couple times but wonder if you used a generous amount of anti static clothes spray on the material and bit if that might help any?
    Words of Wisdom:
    Nov 2006
    LaGrange GA
    Static is tough on anything. I am glad it's getting warm here in GA
    I cut PVC all the time and with a good dist collector it isn't bad.
    Sep 2012
    Blaine Mn
    I have switched from HDU to PVC lately and have no problems at all.
    The A&B is all pvc and the Tebco is pvc and acm. Gene
    cnc routing, portland or
    Yes I cut it all theme. when it was bad when it had a plastic protective sheet. removing it was like getting tazed. I would have juice run up my headphone cards and zap my ears and change the volume on my iPhone. vacuuming the table can be a charged experience too.
    Aug 2012
    Bloomingdale NJ
    I've just begun experimenting with Sintra and am happy with the results. Here is a photo of my first try.
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    Mayo,
    A perfect oppertunity to make extra money . Collect that stuff and sell it to a movie set that needs snow
    Apr 2010
    Brunswick, GA
    I've used a product called Sprayon SP610 Anti-Static Spray when machining plastics/corian. I spray some on a rag and wipe onto the surfaces where I want to minimize static cling. I ordered some from Amazon last year, but it's not available there anymore. I see it's available from Grainger (and several other places too). Here's a link to the Grainger source:
    http://www.grainger.com/product/SPRA...AS01?$smthumb$
    It is supposed to be completely safe to use on metals and plastics, and it's persistent (lasts a lot longer than consumer dryer sheets and sprays). Industrial manufacturers use it to eliminate or reduce static cling on their equipment.
  1. Some music insturments
    By genek in forum Folder 2013
    Last Post: 04-25-2013, 12:54 PM
  2. Cutting a State Shaped Cutting Board
    By TJ in forum Camp ShopBots/User Groups/Training Classes
    Last Post: 03-07-2013, 03:57 PM
  3. Why We Dislike Customers
    By CNYDWW in forum ShopBotter Message Board
    Last Post: 08-22-2011, 08:11 PM
  4. Free radio pick your type of music
    By gene in forum ShopBotter Message Board
    Last Post: 09-17-2009, 09:48 AM
  5. Challenges Cutting Hardwood - cutting moves panel with vacuum
    By kenakabrowncom in forum Archive2008
    Last Post: 09-26-2008, 12:41 AM
