Results 1 to 10 of 16
Thread: Vacuum loss auto shut down
    Apr 2014
    Warren RI
    Default Vacuum loss auto shut down
    My apologies if this has been covered before but I couldn't find it if it has.
    Has anyone figured out how to wire the emergency shut off switch to a vacuum gauge/sensor?
    We are machining small plastic parts using a custom gasket spoil board to hold them with a 25"-Hg vacuum pump. See the pictures below.
    https://goo.gl/photos/TmZ9zJaQXasuhzP56
    https://goo.gl/photos/cBpJ2Hq5nzNm26iFA
    It works really well until it doesn't. If one of the parts has a chip under it and jumps off you lose vacuum for all the parts and if you don't catch it right away can trash the rest of the stock and the spoil board.
    What I would like to figure out is a way to have a sensor on the vacuum system so that if it drops below a certain level it trips the emergency stop. Has anyone done this? I am sure I can figure it out but would much rather copy someone else than start from square one.
    Oliver
    Moore Brothers Co
    You could hook up your sensor to an open input and then set that input (VN) to either normal open stop or normal closed stop, whichever is right for your sensor contact type.
    You could also put it inline with the E-stop, as long as it is of the proper contact type (Normal Closed for newer tools), but would probably want a way of bypassing it when doing other jobs.
    Another option would be to have set as a 'standard switch' input and then in the file, monitor that input and if it is true, it could be told to PAUSE and give you a warning message. More complicated, but should work. Likely that you would loose position with any of these and you'd need to reset. Not a big deal if you set it up at the start and just C3 again.
    Apr 2014
    Warren RI
    Right but a pressure sensor isn't going to be an open/close switch. You need some way of taking the pressure reading from the sensor and setting a limit that triggers a switch. The sensor needs to have a set point at which it triggers the input like you said. I think I can do it with a pretty simple raspberry pi setup but was hoping some one would know of a less custom solution.
    Pretty sure Jerry is talking about a gauge you might find from the following google search.
    https://www.google.com/search?source....0.LkG5LcHqVH0
    I've seen it discussed but haven't seen anyone define what gauge or their source.
    Yes, wrong terminology. You just need some kind of vacuum switch that will go Open or Closed when the vacuum drops out. Should be easy enough to find one that would do the trick. After that, all you need to do is wire it to an input and set it accordingly in SB3.
    Be prepared to spend some money. You'll need a decent sensor (times the number of zones you want to monitor), an arduino (much easier and better suited to the task than messing with a Raspi) and some time to tinker. You can get fancy with an LCD and rotary switch to navigate through menus and set your trigger points. Then, just output a signal and 'listen' for an input (whatever one you have setup) in SB3.
    Nobody here that I am aware of has done this, so plan on doing lots of your own research. I suggest checking out Ebay for vacuum switches and transducers, avoiding the cheapest ones, and the Arduino forums for the code. It's best to copy/paste something that is known to work and hack it to fit your needs for testing.
    Components have gotten a lot cheaper but it still may be a big number when you factor everything in. Personally, I would not want it to stop the machine, but do some kind of corrective action like shutting off the 'troubled' zone. There are lots of ways to do that but they cost money. For comparison, I think it was somewhere around $1000 to pneumatically control my vacuum zones & that was with me building my own actuators using Gary Campbell's fine example...
    If you do wind up doing this project, please post up your findings so that others can follow your lead.
    Apr 2014
    Warren RI
    Wow. It always amazes me how close and yet so far you can be with a google search. I figured they had to exist I just couldn't find them. And they popped right up on your search:
    http://www.omega.com/pptst/PSW-500.html?pn=PSW-521
    Those guys look like they might do the trick.
    Thanks for the help.
    Brady, I hear you and that was why I was really hoping someone had already done it. For each set up we are only running one zone so I figured a stop and a deal would be my only option.
    My brother (and business partner) has been playing with raspi parts making cameras and the tinkering time is significant for sure.
    Now to go find some of that spare time...
    Oliver
    cnc routing, portland or
    maybe this is a way to go thats practical. when I built my vac pump for a vac bag the kit had a pressure switch to turn the pump off and off. I doubt it was too much since the only thing was about 100 or so. but all you need to do is hook it up to a flashing light maybe not quite as good but it is a simple solution.
    Oct 2011
    Colorado
    I've started on a similar project, but I'm in my busy season, so it will wait until summer. There are a couple of approaches you can take.
    1. The simplest is likely using a pressure switch from joe woodworker and connecting to an input. You don't want to hit an e-stop as that can result in lost steps and the need to reset your axis locations. A few relatively simple lines of code that calmly stop the machines motion and display a warning is all that is necessary. The part would be:
    http://www.veneersupplies.com/produc...er-18-NPT.html
    2. A programmable system that gives greater monitoring of other components in your system might include a plc or an adruino utilizing a barometric pressure sensor. This requires more programming and some elctronic experience. but can be used to perform a similar task of machine shut down based on vac pressure or any other sensors you might wish to implement.
    Apr 2014
    Warren RI
    Quote Originally Posted by donek View Post
    That is definitely a more affordable option. I will see if I can make it happen.
    I started looking through your youtube channel again last night. I really like your press temperature controller. Very slick. We've started batting ideas for something similar. I really like the enclosure that lays flat. Much better than jamming it all in the grey box that is too small. We need to sort something out better than our current temp controllers if we are going to start curing prepregs in house. Our current move is to use an autoclave at another company down street.
    I am also super jealous of your edge bender. We are chasing the custom ski dream as well and have dreams of making something like your bender.
  1. Loss of Vacuum Hold Down
    By jdervin in forum Troubleshooting
    Last Post: 04-12-2015, 07:50 AM
  2. Shut off router BEFORE jog home
    By sbd1 in forum ArtCAM
    Last Post: 10-20-2012, 05:48 PM
  3. Y axis shut down
    By meatbal80 in forum Assembly & Maintenance
    Last Post: 06-09-2011, 03:55 PM
  4. How do I shut off router?
    By robert in forum Archives2007
    Last Post: 10-20-2007, 12:58 PM
  5. Router shut-off
    By insculp in forum Archives2005
    Last Post: 01-29-2005, 10:44 AM
