Results 1 to 4 of 4
Thread: Bandsaw blade brazing jig
    May 2011
    ny
    Default Bandsaw blade brazing jig
    I finally got around to making a jig for brazing my blades I was using a angle iron guide and clamps before but nothing was welded up.
    This setup works really well I prefer brazing to welding the blades I have never had a braze joint let go.
    I grind a lap joint for a nice overlap, a piece of brazing rod pounded flat is inserted in the joint with some boric acid powder as flux, hit it with the torch and its all set, the pictures I think are self explanatory.
    May 2011
    ny
    More pictures
    A little cleanup of the joint is done on the end of my 6x48 belt sander
    Jun 2013
    Pasadena, CA
    Oh wow, that looks simple enough. I never tried that.
    Do you use high silver solder? And is there any heat treatment necessary after brazing?
    May 2011
    ny
    Quote Originally Posted by Burkhardt View Post
    No I use regular brazing rod I have not heat treated either I have a blade welder the last step on that is to anneal the blade so the slow cooling off from the torch should be fine, I prefer brazing them than using my blade welder.
  1. More Bandsaw Letters
    By joe in forum Sign Making
    Last Post: 06-23-2016, 11:38 AM
  2. A projector, swivel knife & Bandsaw
    Last Post: 10-24-2015, 11:15 AM
  3. Bridgewood Bandsaw parts supply?
    Last Post: 10-02-2013, 05:23 PM
  4. Saw blade for cnc?
    By kevin in forum Variations & Modifications of ShopBots
    Last Post: 11-22-2012, 07:47 AM
  5. Doh... I own a bandsaw!
    By harryball in forum Archives2007
    Last Post: 01-09-2007, 08:38 AM
