Results 1 to 7 of 7
Thread: Two-sided Carving a Dish
    Jun 2012
    Heathsville, VA
    Default Two-sided Carving a Dish
    At the risk of being told there are better ways to do this ;-) (to which I agree there are always improvements to be made), here is a video I posted that shows how I used Aspire and a ShopBot Desktop to make a nice, graceful wood dish. I hope it helps someone here. And, if you look very closely you can see that I changed from a raster roughing tool path to a z-level roughing tool path on the inside between the day I filmed the ShopBot action and the day I recorded the Aspire work. Continuous process improvement, right? Andy
    https://www.youtube.com/watch?v=i5ojCcb-7GA
    Andrew Pitts ~ FurnitureMaker
    AndrewPittsFurnitureMaker.com
    Very cool...i admit i skipped thru the video some, and maybe you talked about it, but what length bit did you use having to use 2.5" material?
    Also have you experienced any cupping or warping after having cut away so much material? I did a deep cutting and carving on some 10 year dry walnut for a blanket chest lid and it cupped terribly after releasing all the material from around the carving. Excellent work!
    Words of Wisdom:
    Jun 2012
    Heathsville, VA
    Thanks Jack! The bits are 3" long with 1-1/4" cutter length. Fully engaged in the collet, the bit shows 1-3/4", pretty tight for this deep cut. I cheat a little on the collet to get some more exposure of the bit. I'm using KD wood from my solar kiln at about 7-8% MC and did not see any reaction of the wood. I do get some reaction from the parts of my Insignia Box, that are 10" w x 12" l, same wood from the same kiln. Could be that the dish is too thin to react, or maybe since it's curved I just cannot see the reaction. Andy
    Excellent video, process, and commentary Andy! I like doing bowls and platters this way. So many options, just wish I had more time to do them.
    NICE Andy
    Thank you!!
    Jun 2012
    Heathsville, VA
    Thanks Scotts.
    I knew there were too many of us
    That's why I'm the lower key scott
    Anybody heard from Scott Shilala? Back stuff is serious...small messages from friends help more than you might imagine!
  1. How do you dish out a bowl
    Last Post: 09-05-2016, 08:55 PM
  2. Dish washer trouble
    By kevin in forum ShopBot Businesses
    Last Post: 08-20-2012, 09:00 PM
  3. dog dish holder
    By Ajcoholic in forum Folder 2012
    Last Post: 04-04-2012, 09:51 PM
  4. Heart shaped dish
    By tkovacs in forum Folder 2008
    Last Post: 01-23-2008, 09:35 PM
  5. Trying to make a radiused dish
    By betacrash in forum Archives2007
    Last Post: 01-07-2007, 01:20 PM
