Results 1 to 6 of 6
Thread: Rotary Phase Converter for ShopBot PRS Alpha, Colombo spindle, Republic blower/vacuum
    Sep 2011
    Bowling Green, OH
    Default Rotary Phase Converter for ShopBot PRS Alpha, Colombo spindle, Republic blower/vacuum
    Hi there,
    My shop is about to move to a new location with only single phase power.
    Our ShopBot PRS Alpha with a 5HP Colombo spindle and a 16.9HP Republic blower/vacuum requires 3 phase power, though. We'd obviously need a rotary phase converter.
    Questions:
    - Any specific recommendations?
    - Should I get a cheaper 20HP phase converter for the blower/vacuum and a high-end 5HP converter for the spindle or is it better to one bigger high-end for both?
    I've looked at several models at
    Precision Electric
    https://www.precision-elec.com/produ...se-converters/
    as well as
    American Rotary
    https://www.americanrotary.com/produ...se-converters/
    Thank you for your help in advance!
    Erwin
    Dec 2011
    Piedmont, SD
    Erwin,
    A single 3 Phase convertor and circuit in your building is all you'll ever want to have to deal with.
    IMPORTANT: You will be advised by the manufacturer of any rotary to purchase a unit rated twice the required horsepower. This means you need a 40. Rotary's just need that headroom. Okay, some may say only 50% more, but you get the gist. 20HP rotary is not enough for the loads you're going to subject it to.
    I graduated out of a 40HP rotary last year for a similar load rating, and got a Phase Perfect. Due to the nature of these units, rather than the 40HP they'll recommend for a rotary, you may now use a 20. For the price I see AR quoting for an entry level 40HP, you can get a 20HP digital from Phase Perfect. I would never desire to go back to a rotary - big noise, and though obviously a brand new unit would be tuned in well, it still cannot compare to the accuracy of the Digital.
    I literally would have voided my warranty on a new shaper, had I fired it up with the old rotary I had, as the hot leg was putting out 270v. Up to that point, the wide-belt sander I was originally using it for has no microprocessor controls, so it didn't care. That old rotary needed re-balancing due to aging capacitors and the relation of incoming voltage to load. Every building and load configuration is different. Could have hired, (if I could find someone), to spend an afternoon on the phone in consultation with the manufacturer, testing and re-wiring capacitor array to pull into balance, but by then, I would have been half way invested in the digital from Phase Perfect, which automatically balances the load to within +/- 1% of incoming voltage. And no moving parts.
    Check it out. It is the ideal way to go. You will find it liberating, once you get a solid digital 3phase circuit going in your shop, as the stability of it's power for the ever-evolving world of microprocessor controlled machinery is eventually going to push you to this level of accuracy, IMHO.
    Might as well invest there at the outset, as I hope you are able to.
    Jeff
    Sep 2011
    Bowling Green, OH
    Thanks, Jeff!
    VFD is probably the way to go then. Did you try it was a ShopBot spindle and blower as well?
    Erwin
    Dec 2011
    Piedmont, SD
    Definitely not a VFD, which seems lately is regularly being sited as some sort of budget phase conversion shortcut. Just give them a call regarding your needs, and they can explain it much clearer.
    My spindle and hold-down systems are not 3phase so I cannot speak to that, but it all simply boils down to the horsepower ratings.
    jeff
    Sep 2011
    Bowling Green, OH
    Got it! Thanks again!
    Jun 2018
    Pennsauken, NJ
    Interesting info that I'll keep on file. I use an OLD rotary converter for my sheet metal shear, if only because that's what it came with.
