Originally Posted by
Brady Watson
You gotta power up the machine and shake it down. Starting at the spindle, lift it, push, pull, wiggle and both listen and feel for slop. The following are the major sources of backlash/hysteresis/slop in these machines:
1) Z pinion gear to rack lash. Pinions wear and the mesh loosens up. Loosen up the four 3/16" socket head cap screws holding the Z motor on the back of the YZ car and pull it out of mesh with the rack, then slide it all the way back in to engage into the rack and tighten it up. Check your work. If it's still sloppy, do it again.
2) The YZ car bottom V-rollers that ride on the bottom of the beam are loose. Get the funny looking flat wrench that came with the tool and adjust the eccentrics on the bottom V-rollers until they touch the bottom rails. Then tighten an additional 1/8 turn. Don't make them too tight...When they are loose, the entire YZ car can lift up.
3) Depending on the year and generation of PRS tool you have the adjustment procedure varies...Have a close look at the bearings that guide the Z axis. Move the Z 1" off the spoilboard and try to wiggle the spindle in all directions. Move it up another 1" and repeat this procedure. Keep advancing in 1" increments until you've covered the entire stroke, noting any slop in the Vroller bearings/rails that guide the Z. On later tools, the rails are female and the adjustment is on center wheel of the 3 wheels that ride on the rails. Take care not to cut yourself on the female rail...they get razor sharp.
