just typing SO,1,1 doesn't turn on the router...you have to then make a move or run a file at which time you'll get the prompt to press the green button on the control box then hit enter to continue, or something like that. When entering moves manually using Move,Jog, or Cut commands, you will get the prompt each time you enter a command that would cause the machine to move, then the router will turn off after the move. You have to press the green button to turn the router on for each move. (Of course the ShopBot doesn't know if the router is on. If you are making a jog move and don't need it on, just hit enter without pressing the green button)
When using the SO command within a file, you will get the prompt the at the first instance of the SO,1,1 command within a file. If the file then includes SO,1,0 (router off), and then SO,1,1 (router on) again, the router will turn on immediately with no prompt. The Keyboard mode works similarly, once the router has been turned on you can turn it off and on at will without having to press the green button again.
