Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Is it really necessary to fiddle with ramps from job to job?
    , South Jordan Utah
    Gerald, You're right about me being off on a tangent. That's often the case. In fact, I can often go for days on end going from one interesting problem to another before finally getting back to the original problem.
    Now back to the subject at hand . . . As I see it, the goal is to command the machine to start at an exact point on a line segment, to move an exact distance and then to stop exactly at the desired point on that line segment. (I'm using the term 'line segment' on purpose because it's my understanding that even the smallest circles are cut by commanding the machine to move through many straight line segments, with most of the complexity needed to convert a circle or curve to line segments being handled by the tool path program or the native instruction set of the machine.)
    Since a stepper motor, like a car, needs to accelerate to get to speed, a programed ramp is normally used. Trying to accerate a car too quickly either stalls the engine, if the engine doesn't have enough power to do what the driver commands, or the tires lose traction and 'burn rubber'. In either case. A stepper that is commanded to move too quickly either completely stalls or loses steps, with neither condition being acceptable. Also, a stepper motor, like a car needs to slow down gradually or a 'skid, i.e. overshoot occurs. Just like you wrote, an experienced driver knows his car and compensates with his skills to make the car do exactly what he desires. That point being conceded, let's try to figure out whether mechanical control, i.e. sensor feedback and automatic compensation, or programming would work best to control acceleration ramping and deceleration ramping on a CNC machine.
    Programmed ramping to accelerate a stepper motor, if convervative ramping is used, assures that the motor with neither stall nor lose steps. It also guarantees that the motor will not be running at its peak speed because the ramp will have to be conservative enough to allow for unknown differences in the material or cutter sharpness, etc. On the other hand, a sensor based system, would sense a missed step and then automatically slow the motor down. An intelligent sensor system would compensate for missed steps to assure accuracy. In other words, a sensor based system could be commanded to ramp at an unrealisticly high rate and then compensate for all known and all unknown factors automatically.
    Deceleration is another matter entirely. In my experience, if a motor is not ramped down properly, overshoot or skidding occurs. In this case a sensor based system would only know that the motor had gone too far. An intelligent sensor system could reverse the motor until the commanded stop point was reached, but the damage to the material would have already occurred.
    So, in my mind, to follow the programmed tool path, sensor based acceleration would be optimum to get the motor to speed in the shortest distance, but programmed deceleration would be needed to prevent overshoot (skidding) at the end of each line segment. Whether programmed deceleration is left to the machine's operator to figure out or whether it is a function of the machine's control software is another matter entirely. I would assume that deceleration ramping should be a function of the machine's control software (which is why I suggested cutting a rectangle with various corner radii, in the post above - that test shows that Shopbot has done a very good job of incorporating ramping into the control software). Optimizing the deceleration ramping to give optimum performance, equal to sensor based acceleration, would be complex and probably require computer hardware far beyond that supplied with any moderately priced CNC controller.
    Oct 2001
    I believe that sensor based deceleration is actually the easier one because the motors can be such good brakes. Much higher power/torque levels are available under braking. Cars have long had sensor based braking control (ABS), but "launch control" is still in its infancy.
    , South Jordan Utah
    I agree that sensor based deceleration would stop a car or motor in the shortest amount of time. However, if the goal is to stop exactly at a given spot, whether it be on the road or at a given coordinate on the CNC table, a sensor based system whould have to be forewarned that a stop was required before the stop point was reached.
    In the case of my Alpha, which has 1-inch pitch diameter gears on the steppers, if the axis is cutting at 6 inches per second, the motor controller is receiving a pulse train ranging between 381.97 steps per second (if the motor is using full steps) and 3,819.7 steps per second (if the motor is using 1/10 microstep). Because the gantry has mass, going from 380+ steps per second to zero steps per second requires more than just shutting off the pulse train - if the motor is expected to stop at the commanded point and not overrun that exact point. At least that's what I'm basing my response on. Since my expertise in mechanics is extremely limited, I may be making too many assumptions.
    Oct 2001
    "a sensor based system whould have to be forewarned that a stop was required before the stop point was reached." That is exactly why forward-looking software is needed, and why SB software has the forward-looking capability like everyone else. (How far the programs look forward varies)
    Mike, the next time you are driving, analyse what you are intuitively doing with the brake pedal when you see a stop sign and then the stop line.
    Realise that constant force on the pedal is a constant ramp value.
    I don't think that you stab the pedal down nor that you release it instantaneously. In other words, you gently increase the ramp value from zero, hold the force (ramp) steady for a while, and then as you approach the stop line you ease off the pedal until stopped in the right place. (This is the S-shaped ramp mentioned in the linked article).
    Smoothing out the ends of the pedal force (or ramp value) eliminates "jerk". Some more light reading here.
    But, yeah, if you didn't see the stop sign (by looking forward), you are going to overhoot....
    , South Jordan Utah
    Gerald, I think we're both on the same side of the argument, i.e., that deceleration should be controlled by a program, not the program written by the CNC operator, but a program that controls the controller. I think that we both agree that that controller program must have forward-looking software. Whether that software is extremely simple and only knows how many step pulses are required to finish a line segment or whether it is more sophisticated and can look ahead at many instructions to calculate changing forces that will be caused by upcoming instructions, is not necessarily relevant to the CNC owner/operator because that parameter is probably totally controlled by the CNC manufacturer and the software people that write the code to control the controller.
    By the way, I just read the article that you reference above. It's interesting reading which I probably should have read before writing my reply.
    In any case, although I've been in the computer industry longer than Bill Gates, it's still amazing to me that two people separated by half a world can exchange ideas in a matter of minutes.
  1. Tabs, Leads, Ramps... Let's start using them! Online August 27th
    By TJ in forum Camp ShopBots/User Groups/Training Classes
    Last Post: 10-22-2014, 06:24 AM
  2. Delete ramps/lead-ins or fewer parts?
    By Chuck Keysor in forum ShopBotter Message Board
    Last Post: 06-01-2013, 11:22 AM
  3. Ski ramps on rectangles
    By daski in forum Archives2007
    Last Post: 06-13-2007, 11:20 AM
