Results 1 to 10 of 10
Thread: Beveled Letters
    Aug 2006
    Authentic Cabinetworks LLC, minneapolis mn
    Default Beveled Letters
    Can anyone tell me How to create beveled letters in part works.
    Is it possible in partworks?
    Mar 2008
    Radford VA
    Andre - Goto to the Vectric website. They have a tutorial on there about creating beveled letters.
    Jan 2008
    GC Carpentry & Custom Woodworking, Peabody MA
    Not sure if this is the best way, but what I do is use a V-Bit with a V-Carve/Engraving toolpath using the "flat depth" feature and select "Flat area clearance tool", usually an End Mill. You will need to create a border around the text to contain the clearance area. The bevel will depend on the angle of the V-Carve bit.
    Aug 2006
    thanks Brad I will
    I'm guessing it has to do with v carving the area around the letter with a flat bottom depth.
    Aug 2006
    thanks george
    Aug 2006
    So in part works there is no option for sharp outside and inside corners when machining outside vectors with a v bit, Like there is in V-carve pro.
    And when you do an offest of vectors and v-carve that space, partworks leaves rounded out side corners. Does anyone know if there is a solution to this to get sharp outside corners?
    Jan 2008
    Are you using a V-Carve/Engraving toolpath or a Profile toolpath. If the lettering has any sharp outside or inside corners, they should machine as sharp corners at the material surface. The relieved lower surface will look rounded on outside corners.
    Aug 2006
    I am doing that and the lower surface is rounded. how do you create a sharp corner all the way down.
    Jan 2008
    Good question. I think it might have to do with the shape of a V-bit. The edge of the bit follows the path like a straight bit, but when rounding an outside sharp corner, it needs to take a rounded path to avoid cutting beyond the path, so it leaves a sharp corner on the upper surface and a rounded appearance at the deeper surface. Maybe someone else has a method of leaving the outside corners square at the pocketed surface.
    Aug 2006
    Oh Boy do I feel dumb
    There are tabs next to the "tabs buttons in profile tool path that give you the options for sharp inside and outside corners.
    They are shaded out so they are easy to ignore.
    Duhh!
  1. Beveled edge
    By jbworden in forum Archives2007
    Last Post: 12-29-2007, 11:11 AM
  2. Sharp Corners on a V Beveled Frame
    By rickh in forum Archives2007
    Last Post: 09-23-2007, 02:25 AM
  3. Beveled flat top text
    By ljdm in forum ArtCAM
    Last Post: 08-30-2007, 09:03 AM
  4. How to cut beveled edges for trapezoidal boxes
    By mthomas in forum Archives2006
    Last Post: 02-20-2006, 01:50 AM
  5. Raised Beveled Letters
    By joe in forum Archives2004
    Last Post: 03-21-2004, 10:41 AM
