Results 1 to 10 of 17
Thread: Cutting Polycarbonate Profiles, Help!
    Jun 2010
    Venice, CA
    Angry Cutting Polycarbonate Profiles, Help!
    Hi all,
    I am attempting to cut 2D profiles from 0.25" Polycarbonate sheet. We are getting a chattery edge on all radius as well as entry/exit points. I am using a Shopbot Buddy and an Onsrud 66-087 single O-flute Edge Rounding cutter at 100ipm and 15,000rpm.
    We are getting great results in the straightaways but the curves are bumpy and the entry and exit point is very chattery. I think by extending our entry/exit lengths and radius I can fix that problem, but what settings do I need to alter to get a more consistent finish in the curves?
    I read thru the forums and tried altering the ramp settings but there was no change in our edge quality.
    Thanks in advance
    Keith
    IDS
    Venice, CA
    Apr 2007
    Marquette, MI
    Keith...
    Did you save the file using the "arcs" postP?
    Which program did you create the vectors with?
    Gary Campbell
    GCnC Control
    GCnC411(at)gmail(dot)com
    Servo Controller Upgrades
    Albert Einstein
    Jun 2010
    Venice, CA
    Gary,
    We use Rhino with RhinoCAM and export to the Shopbot. Postprocessor is Shopbot, not the ShopbotGcode.
    Apr 2007
    Marquette, MI
    Keith...
    It is pretty likely that your design uses short line segments instead of arcs for radius vectors.
    You may want to export vectors to one of the CAD/CAM apps and post using the "arcs" post. It uses gCode arcs and results in much nicer radius cuts.
    Gary Campbell
    GCnC Control
    Albert Einstein
    Norman, Ok
    Keith,
    I think Gary is correct. This has been a problem with SB. Circles and curves which are made from short links seldom cut smoothly. Also Polycarbonate shows every defect. I'm cutting letters from this material which is .75" thick using a V bit. It's a test of nerves since it doesn't sand very well.
    Joe
    Jun 2010
    Venice, CA
    Hey thanks guys,
    I tried to create a Gcode file but it was turning off our spindle when I started the file, any suggestions I dont really understand the coding aspect that well.
    Also our machine is really new, is there any sort of "breaking in" time, where we need to go back and readjust our motors, track etc?
    Jun 2010
    Venice, CA
    Here are some photos of our recent profiles you can clearly see that pattern bump/ridge
    I would try a rough cut with a straight cutter with an offset then the finish cut so you would only be taking off a small amount and putting the bull nose in.
    Jun 2010
    Venice, CA
    Ok I ran a Gcode file, *.gcc and got the Same Problem. This leads me to believe it is the ramping in the Shopbot controls, any suggestions?
    I also tried a straight cutter roughing and the bullnose only taking .020" and still no luck.
    Jun 2010
    Venice, CA
    Is this correct for Gcode? I had to delete M03 as a command because it was turning off our spindle.
    G90
    G00Z1.0000
    X14.9403Y23.3034
    G01Z-0.09F 40
    X14.6903F 40
    X14.625Y23.3077F 80
    X14.5608Y23.3205
    X14.4989Y23.3415
    X14.4403Y23.3704
    X14.3859Y23.4067
    X14.3367Y23.4499
    X14.2936Y23.499
    X14.2572Y23.5534
    X14.2283Y23.6121
    X14.2073Y23.674
    X14.1945Y23.7382
    X14.1903Y23.8034
    Y24.9284
    X14.1862Y25.0427
    X14.174Y25.1563
    X14.1537Y25.2688
    X14.1254Y25.3796
    X14.0893Y25.4881
    X14.0455Y25.5937
    X13.9944Y25.6959
    X13.936Y25.7943
    X13.8708Y25.8882
    X13.7991Y25.9772
    X13.7212Y26.0609
    X13.6375Y26.1388
    X13.5485Y26.2105
    X13.4546Y26.2757
    X13.3563Y26.334
    X13.254Y26.3852
    X13.1484Y26.429
    X13.04Y26.4651
    X12.9292Y26.4933
    X12.8167Y26.5136
    X12.703Y26.5258
    X12.5888Y26.5299
    X10.5888
    X10.5163Y26.5255
    X10.4448Y26.5124
    X10.3755Y26.4908
    X10.3092Y26.461
    X10.2471Y26.4235
    X10.1899Y26.3787
    X10.1385Y26.3273
    X10.0937Y26.2701
    X10.0562Y26.208
    X10.0263Y26.1417
    X10.0047Y26.0724
    X9.9916Y26.0009
    X9.9873Y25.9284
    Y23.4284
    X9.9914Y23.3324
    X10.004Y23.2372
    X10.0248Y23.1433
    X10.0537Y23.0517
    X10.0905Y22.9629
    X10.1348Y22.8777
    X10.1865Y22.7966
    X10.245Y22.7204
    X10.3099Y22.6495
    X10.3807Y22.5846
    X10.457Y22.5261
    X10.538Y22.4745
    X10.6232Y22.4301
    X10.712Y22.3934
    X10.8037Y22.3645
    X10.8975Y22.3437
    X10.9928Y22.3311
    X11.0888Y22.3269
    X13.8388
    X13.8937Y22.3313
    X13.9474Y22.3441
    X13.9983Y22.3652
    X14.0454Y22.3941
    X14.0873Y22.4299
    X14.1231Y22.4718
    X14.1519Y22.5188
    X14.1731Y22.5698
    X14.1859Y22.6234
    X14.1903Y22.6784
    Y23.8034
    X14.1945Y23.8687
    X14.2073Y23.9328
    X14.2283Y23.9948
    X14.2572Y24.0534
    X14.2936Y24.1078
    X14.3367Y24.157
    X14.3859Y24.2001
    X14.4403Y24.2364
    X14.4989Y24.2654
    X14.5608Y24.2864
    X14.625Y24.2991
    X14.6903Y24.3034
    X14.9403F 40
    G00Z0.91
    X14.9203Y23.3034
    G01Z-0.09F 40
    X14.6703F 40
    X14.605Y23.3077F 80
    X14.5408Y23.3205
    X14.4789Y23.3415
    X14.4203Y23.3704
    X14.3659Y23.4067
    X14.3167Y23.4499
    X14.2736Y23.499
    X14.2372Y23.5534
    X14.2083Y23.6121
    X14.1873Y23.674
    X14.1745Y23.7382
    X14.1703Y23.8034
    Y24.9284
    X14.1662Y25.0412
    X14.1542Y25.1535
    X14.1341Y25.2646
    X14.1062Y25.374
    X14.0705Y25.4811
    X14.0273Y25.5854
    X13.9768Y25.6864
    X13.9192Y25.7834
    X13.8548Y25.8762
    X13.784Y25.9641
    X13.707Y26.0467
    X13.6244Y26.1236
    X13.5365Y26.1945
    X13.4438Y26.2589
    X13.3467Y26.3165
    X13.2457Y26.367
    X13.1414Y26.4102
    X13.0343Y26.4459
    X12.9249Y26.4738
    X12.8138Y26.4938
    X12.7016Y26.5059
    X12.5888Y26.5099
    X10.5888
    X10.5187Y26.5057
    X10.4496Y26.493
    X10.3826Y26.4721
    X10.3185Y26.4433
    X10.2584Y26.407
    X10.2032Y26.3637
    X10.1535Y26.314
    X10.1102Y26.2588
    X10.0739Y26.1987
    X10.045Y26.1346
    X10.0242Y26.0676
    X10.0115Y25.9985
    X10.0073Y25.9284
    Y23.4284
    X10.0114Y23.3342
    X10.0237Y23.2406
    X10.0441Y23.1485
    X10.0725Y23.0585
    X10.1086Y22.9714
    X10.1522Y22.8877
    X10.2028Y22.8081
    X10.2603Y22.7333
    X10.324Y22.6637
    X10.3936Y22.5999
    X10.4684Y22.5425
    X10.548Y22.4918
    X10.6317Y22.4483
    X10.7189Y22.4121
    X10.8088Y22.3838
    X10.901Y22.3634
    X10.9945Y22.351
    X11.0888Y22.3469
    X13.8388
    X13.8906Y22.351
    X13.9412Y22.3632
    X13.9893Y22.3831
    X14.0336Y22.4102
    X14.0732Y22.444
    X14.1069Y22.4836
    X14.1341Y22.5279
    X14.154Y22.576
    X14.1662Y22.6266
    X14.1703Y22.6784
    Y23.8034
    X14.1745Y23.8687
    X14.1873Y23.9328
    X14.2083Y23.9948
    X14.2372Y24.0534
    X14.2736Y24.1078
    X14.3167Y24.157
    X14.3659Y24.2001
    X14.4203Y24.2364
    X14.4789Y24.2654
    X14.5408Y24.2864
    X14.605Y24.2991
    X14.6703Y24.3034
    X14.9203F 40
    G00Z1.0000
    G29
    G28
    M05
    M30
  1. converting lawn chair profiles to vectors for cnc cutting
    By woodman08 in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-17-2014, 12:35 AM
  2. Cutting triple walled polycarbonate
    By anothernewbie in forum ShopBotter Message Board
    Last Post: 02-10-2012, 09:14 AM
  3. Cutting profiles or machining on 3d objects
    By macswell in forum PartWorks
    Last Post: 02-17-2010, 09:29 PM
  4. Speeds for .08 polycarbonate
    By waynek591 in forum Archive2008
    Last Post: 06-27-2008, 01:15 PM
  5. POLYCARBONATE AND VACUUM
    By terrye in forum Archives2006
    Last Post: 10-10-2006, 02:29 AM
