Results 1 to 4 of 4
Thread: Pinions and Motor Shafts
    Feb 2015
    Alberta
    Default Pinions and Motor Shafts
    Powered up the bot and was checking it and noticed some play on the X1, X2 and Y motors.
    I knew the X2 was a little loose but was surprised that play developed in the other motors.
    It it common maintenance requirement to have to re-tighten the pinion set screws on to the motor shafts after x hours of operation?
    Thanks for your replies.
    James
    cnc routing, portland or
    my last set of pinions had smaller setscrews it made it harder to get them tight. locktite will fix it and a lot of tightening though the small annalen wrench needed now makes it harder.
    Feb 2015
    Alberta
    Knight_Toolworks;
    Bought the bot used and noticed when I re-mounted the X2 motor that there were lots of set screw marks on the shaft. Do you find that it's your experience that you need to tighten the set screws every so often?
    James
    I did when I replaced them they all came loose. so some locktite and really working on them has take care of it. they used to be 1/4 -20 now they are 8/32 if I remember right.
  1. New Pinions, how snug should we be?
    By jTr in forum Assembly & Maintenance
    Last Post: 05-15-2015, 10:21 PM
  2. geasing the pinions
    By Ajcoholic in forum ShopBot Buddy
    Last Post: 04-21-2012, 03:06 PM
  3. Loose pinions
    By Acmeaviator in forum ShopBotter Message Board
    Last Post: 01-02-2012, 09:20 AM
  4. Help with new pinions
    By frankwilliams in forum Archives2008
    Last Post: 05-05-2008, 09:44 PM
  5. G4 UPGRADE AND NEW PINIONS
    By robert_cheal in forum Archives2007
    Last Post: 02-11-2007, 04:16 PM
