Sign carving tape
I use regular contact paper on my pegboard signs (5.5" x 18") and I have a problem with the contact pealing off on the center of A,P,B's and other letters cutting with the V bit. The carved area is then painted.
The wood is pre painted and sanded with 220 grit and is completely cleaned off.
I tried transfer tape and had the same results.
Question: Is there any good high tack tape ? material that you have luck with?
- You may not post replies
- You may not edit your posts
Forum Rules
