Originally Posted by
paul_z
"I do have excess motor cable looped under the table" If it is all coiled in one direction, it forms an inductor (coil). It would only be a micro henry or so but still a coil. if you take half of the coil, flip it 180 degrees, and lay it on top of the other half, the halves cancel out each other. Per your description of your problem, I don't think a coil is your problem but it would still be good practice to eliminate it as a source of problems.
Be sure that your data and power wiring are as far away from each other as practical avoiding mutual inductance.
I would also recommend that you get a cheap AM pocket radio (with an earphone). Yeah, I know this sounds like a joke; It isn't. Tune the radio to part of the band where you don't hear any station. You now have an extremely sensitive RF sensor. If you experiment with it some, you'll find that the H Field (magnetic) antenna is highly directional.
If you have an intermittent power connection you'll be able to here it and locate it by moving the radio around. If you use a single to three phase inverter, you are likely to hear that as well and will soon be able to determine normal operation.
The radio will also detect static discharges as an audio "snap". You might want to record the audio. If the recording captures a "snap" and everything shuts down, you know what to look for.
I have used this technique to debug an avionics computer. It served as another modality of detecting abnormal operation.
The technique has also been used to detect the operation of electrical welders and plasma cutters at considerable distance even when there were no other indicators.
Paul Z
